[postgis-tickets] [PostGIS] #2729: [raster]: raster crashes when compiled with --enable-debug under windows
PostGIS trac at osgeo.org
Fri May 9 01:01:47 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:  windows  |
Comment(by strk):
 Copying the stack trace over:
 #0  0x000007fefd8e5a01 in strlen () from C:\Windows\system32\msvcrt.dll
 #1  0x000000000074df39 in fmtstr (target=0x23ce320, pointflag=<optimized
 out>, maxwidth=0, minlen=0, leftjust=0, value=0x0) at snprintf.c:779
 #2  dopr (target=target at entry=0x23ce320, format=0x39b131 "",
 args=0x23ce458 "A4ñü_\a", args at entry=0x23ce438 "") at snprintf.c:714
 #3  0x000000000074e13f in pg_vsnprintf (str=<optimized out>,
 count=count at entry=1023, fmt=fmt at entry=0x39b118 "[%s:%s:%d] GDAL_SKIP =
 %s", args=args at entry=0x23ce438 "") at snprintf.c:154
 #4  0x000000000057c0b1 in appendStringInfoVA (str=str at entry=0x23ce3e0,
 fmt=fmt at entry=0x39b118 "[%s:%s:%d] GDAL_SKIP = %s",
 args=args at entry=0x23ce438 "") at stringinfo.c:137
 #5  0x000000000071607f in errmsg_internal (fmt=fmt at entry=0x68701c5f
 "[%s:%s:%d] GDAL_SKIP = %s") at elog.c:821
 #6  0x0000000068684826 in rtpg_assignHookGDALEnabledDrivers () at
 rt_pg.c:112
 #7  _PG_init () at rt_pg.c:237
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2729#comment:1>
