[postgis-tickets] [PostGIS] #2987: ERROR: BOOM! Could not generate outside point!
PostGIS trac at osgeo.org
Fri Nov 7 14:38:41 PST 2014
 Reporter:  jczaplewski  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.5
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by jczaplewski):
 Sorry about that! After some additional testing I've realized I can only
 repeat this issue on the full dataset, which is 750MB (national coverage
 of state-level geologic maps). If I take a subset of it and run the same
 query I don't encounter this error.
 What would be the best way for me to give you a copy of this dataset? I
 could zip it and put it on a server somewhere, if that works for you.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2987#comment:2>
