[postgis-tickets] [PostGIS] #2987: ERROR: BOOM! Could not generate outside point!
PostGIS trac at osgeo.org
Fri Nov 7 14:45:02 PST 2014
 Reporter:  jczaplewski  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.5
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by pramsey):
 There's probably one particular row that's causing the error. By "bisect"
 I mean do something like this. If you had a table of, say 100 entries,
 you'd find the offending entry by going
     WITH subset AS ( select * from mytable limit 50 offset 0 ) SELECT *
 FROM table WHERE ST_Intersects()
     WITH subset AS ( select * from mytable limit 50 offset 50 ) SELECT *
 Then you'd know if the problem was in the first or last half of the data.
 So if the problem was in the last half you could go
     WITH subset AS ( select * from mytable limit 25 offset 50 ) SELECT *
     WITH subset AS ( select * from mytable limit 25 offset 75 ) SELECT *
 And then you'd know if it was first or last part of *that* half, and so on
 until you're down to only one bad record.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2987#comment:3>
