[postgis-tickets] [PostGIS] #2989: Debbie failing on interrupt test
PostGIS trac at osgeo.org
Mon Nov 10 03:52:53 PST 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 winnie is failing too on interrupt.  She's running against 3.5. Hers might
 be slightly out of date 3.5 since I think she was trying to run PostGIS
 and 3.5 build at same time.  So I'll rerun hers after she is done
 rebuilding 3.5
 FWIW her error on 11/6 was:
 PostgreSQL 9.4beta3, compiled by Visual C++ build 1800, 64-bit
   Postgis 2.2.0dev
  - r13121
  - 2014-11-06 18:50:05
   scripts 2.2.0dev r13121
   GEOS: 3.5.0dev-CAPI-1.9.0 r4028
   PROJ: Rel. 4.8.0, 6 March 2012
   SFCGAL: 1.0.4
  interrupt .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_63_diff)
 --- interrupt_expected  2014-11-06 13:48:16 -0500
 /projects/postgis/tmp/2.2.0dev_pg9.4_geos3.5.0dev_gdal1.11.1w64/test_63_out
 2014-11-06 13:57:35 -0500
 @@ -1,5 +1,5 @@
  ERROR:  canceling statement due to statement timeout
 -buffer interrupted on time
 +buffer interrupted late: 00:00:00.25
  NOTICE:  liblwgeom code interrupted
  segmentize interrupted on time
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2989#comment:2>
