[postgis-tickets] [PostGIS] #2989: Debbie failing on interrupt test
PostGIS trac at osgeo.org
Mon Nov 10 12:14:11 PST 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 and yet a hitrd permutation from debbie:
 PostgreSQL 9.1.9 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
   Postgis 2.2.0dev - r13122 - 2014-11-10 11:37:15
   scripts 2.2.0dev r13122
   GEOS: 3.4.3dev-CAPI-1.8.3 r4029
   PROJ: Rel. 4.7.1, 23 September 2009
 interrupt_relate .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.1w64/test_98_diff)
 --- interrupt_relate_expected   2014-11-10 02:30:33.000000000 -0800
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.1w64/test_98_out
 2014-11-10 03:39:34.000000000 -0800
 @@ -1,5 +1,5 @@
  ERROR:  canceling statement due to statement timeout
 -contains interrupted on time
 +contains interrupted late: 00:00:00.209518
  covers interrupted on time
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2989#comment:3>
