[postgis-tickets] [PostGIS] #2987: ERROR: BOOM! Could not	generate outside point!
    trac at osgeo.org
    Mon Nov 10 07:53:55 PST 2014
 Reporter:  jczaplewski  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.5
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by jczaplewski):
 I upgraded to 2.1.3 and narrowed it down to some problematic geometries.
 Basically, I LIMIT 10 with an offset, and if I do
 ST_Intersects(geom, (SELECT buffer FROM linestring))
 I get the BOOM! error. However, if I wrap the geometry in an
 ST_MakeValid() I do not:
 ST_Intersects(ST_MakeValid(geom), (SELECT buffer FROM linestring))
 Would you like me to pass along the problematic geometries for debugging,
 or should we consider this resolved? Thanks for your help!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2987#comment:7>
