[postgis-tickets] [PostGIS] #2987: ERROR: BOOM! Could not generate outside point!
PostGIS trac at osgeo.org
Mon Nov 10 08:57:40 PST 2014
 Reporter:  jczaplewski  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.5
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by pramsey):
 By wrapping in makevalid you might be inadvertently pushing the whole
 calculation over into geometry space. Make sure that you're in geography
 space with a ::geography cast on the results of make valid. If it still
 works then I consider the matter closed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2987#comment:8>
