[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Fri Nov 28 09:36:54 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by robe):
 I found this which suggests you might have a mixup with 32-bit and 64-bit
 libraries: http://stackoverflow.com/questions/9934549/very-strange-linker-
 behavior
 some suggestions from it
 export LDFLAGS="$LDFLAGS -lm"
 or something like
 LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu
 before configure and make might help.  your paths are probably different
 since you are on freebsd so you might need to play with the paths a bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:7>
