[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Fri Nov 28 09:39:41 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by martin5519):
 I'll look at the paths issue - that came up before and I had tried to
 modify the paths.
 I did not have iconv installed but I did have libiconv installed.  I have
 iconv installed now as well (no difference):
 root at database:~martin/postgis-2.1.4 # whereis iconv
 iconv: /usr/bin/iconv /usr/share/man/man1/iconv.1.gz
 /usr/ports/converters/iconv
 root at database:~martin/postgis-2.1.4 # pkg info | grep iconv
 iconv-2.0_4                    Charset conversion library and utilities
 libiconv-1.14_4                Character set conversion library
 I googled that error you're concerned about - I found the following:
  Sep 23, 2014; 8:15pm
 Re: //lib/libm.so.5: could not read symbols: Bad value and /usr/bin/ld: :
 invalid DSO for symbol `sin@@FBSD_1.0' definition
 Justin Hibbits-2
 Actually it's an issue with the port.  The toolchain guys made ld more
 strict, requiring all libraries to be specified on the command line,
 rather than following the DT_NEEDED links.  There is a whole host of
 ports that have the problem of missing -lm.  Some have been fixed, but
 many more remain.
 - Justin
 So, I suspect this should be fixed first and foremost?  Your thoughts?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:8>
