[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Fri Nov 28 09:57:12 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by robe):
 martin,
 libm as ,pramsey said, is definitely one of the holding blocks.  the
 iconvs are just warnings so may be harmless.
 So since its failing at the linker phase for libm. libm is something you
 have to fix before you can continue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:9>
