[postgis-tickets] [PostGIS] #2962: debbie erroring on 2.2 doc building
PostGIS trac at osgeo.org
Fri Oct 10 05:13:40 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Getting this error:
 generator.c: In function ‘checked_system’:
 generator.c:56: warning: implicit declaration of function ‘WEXITSTATUS’
 gcc -o generator styles.o generator.o ../../../liblwgeom/.libs/liblwgeom.a
 -lm -L/var/lib/jenkins/workspace/pg/rel/pg9.2w64/lib -lcunit
 generator.o: In function `checked_system':
 /var/lib/jenkins/workspace/postgis/docs/branches/2.2/doc/html/image_src/generator.c:56:
 undefined reference to `WEXITSTATUS'
 /var/lib/jenkins/workspace/postgis/docs/branches/2.2/doc/html/image_src/generator.c:57:
 collect2: ld returned 1 exit status
 make[1]: *** [generator] Error 1
 make[1]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/docs/branches/2.2/doc/html/image_src'
 make: *** [images] Error 2
 I tried clean checkout and didn't help.
 before clean check out was giving erros such as
 /usr/include/bits/string2.h: In function ‘__strpbrk_c2’:
 /usr/include/bits/string2.h:1129: error: ‘size_t’ undeclared (first use in
 this function)
 /usr/include/bits/string2.h:1129: error: (Each undeclared identifier is
 reported only once
 /usr/include/bits/string2.h:1129: error: for each function it appears in.)
 /usr/include/bits/string2.h:1129: error: expected ‘;’ before ‘__s’
 /usr/include/bits/string2.h: In function ‘__strpbrk_c3’:
 /usr/include/bits/string2.h:1142: error: ‘size_t’ undeclared (first use in
 this function)
 /usr/include/bits/string2.h:1142: error: expected ‘;’ before ‘__s’
 This seems to have been happening for quite sometime (since September) but
 I didn't notice since it was failing since it was registering as success.
 I suspect its the image building so the html generation is fine which
 might be why I never noticed since html docs were showing up with each new
 change.
 At first I thought this might be a result of patch upgrade on server, but
 it doesn't seem to be affecting 2.1 doc building so think something in our
 trunk code base changed to affect the doc image generator.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2962>
