[postgis-tickets] [PostGIS] #2962: debbie erroring on 2.2 doc building
PostGIS trac at osgeo.org
Fri Oct 10 05:32:46 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 traced down the failure to r12940
 Changes
 Fix typo in DropOverviewConstraints doc (detail)
 Fix warnings in docs image generator build
 Print a warning on system call failures (detail)
 Add documentation for {Add,Drop}OverviewConstraints (#2824) (detail)
 so I presume whatever was done to fix the warnings on image generator
 broke the image generation on debbie
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2962#comment:1>
