[postgis-tickets] [PostGIS] #2965: ST_Distance, use_spheroid default
PostGIS trac at osgeo.org
Tue Oct 14 13:23:27 PDT 2014
 Reporter:  gitai                      |       Owner:  pramsey
     Type:  defect                     |      Status:  new
 Priority:  critical                   |   Milestone:  PostGIS 2.1.5
Component:  postgis                    |     Version:  2.1.x
 Keywords:  ST_Distance, use_spheroid  |
Comment(by pramsey):
 Removing the implicit geometry::geography cast would be a big change,
 though not probably one that would effect many people, since nearly every
 geography function has an exact geometry analogue, so the case of calling
 st_geogfunction(geom) almost never happens current. The reverse, on the
 other hand, happens quite a lot.
 And, in fact, we don't have an implicit cast in the other direct, for
 reasons that are probably good, but I cannot recall.
 select st_x('POINT(1 2)'::geography);
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2965#comment:14>
