[postgis-tickets] [PostGIS] #2965: ST_Distance, use_spheroid default
PostGIS trac at osgeo.org
Tue Oct 14 13:24:01 PDT 2014
  Reporter:  gitai     |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.1.5
 Component:  postgis   |     Version:  2.1.x
Resolution:  wontfix   |    Keywords:  ST_Distance, use_spheroid
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 That said "remove implicit geometry::geography type cast" should be filed
 as an enhancement, not a bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2965#comment:15>
