[postgis-tickets] [PostGIS] #2941: Geography can create a non-4326 geography but geography typmod won't allow it
PostGIS trac at osgeo.org
Sat Sep 27 17:48:21 PDT 2014
it
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 Both Paul and I recall that the geography type had support for other long-
 lat spatial reference systems when 2.1.0 was released.
 http://lists.osgeo.org/pipermail/postgis-devel/2014-September/024532.html
 When trying this it fails:
 CREATE TABLE test(gid serial,geog geography(multilinestring,4269));
 However I can do this:
 SELECT geography(ST_GeomFromText('POINT(1 1)', 4269));
 and this:
 SELECT geography(ST_GeomFromText('POINT(1 1)', 4269)) As geog
 INTO test3;
 SELECT ST_SRID(geog::geometry) from test3;
 --yields 4269 as expected.
 I thought it was a regression bug, but trying the above on a 2.1.0 install
 I found lying around yields the same results.  So it seems while the
 geography type supports non-4326 lon lat spatial reference systems,  you
 can't insert these into a geography table.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2941>
