[postgis-tickets] [PostGIS] #2941: Geography can create a non-4326 geography but geography typmod won't allow it
PostGIS trac at osgeo.org
Sat Sep 27 17:50:04 PDT 2014
it
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Description changed by robe:
Old description:
> Both Paul and I recall that the geography type had support for other
> long-lat spatial reference systems when 2.1.0 was released.
> http://lists.osgeo.org/pipermail/postgis-devel/2014-September/024532.html
> When trying this it fails:
> CREATE TABLE test(gid serial,geog geography(multilinestring,4269));
> However I can do this:
> SELECT geography(ST_GeomFromText('POINT(1 1)', 4269));
> and this:
> SELECT geography(ST_GeomFromText('POINT(1 1)', 4269)) As geog
> INTO test3;
> SELECT ST_SRID(geog::geometry) from test3;
> --yields 4269 as expected.
> I thought it was a regression bug, but trying the above on a 2.1.0
> install I found lying around yields the same results.  So it seems while
> the geography type supports non-4326 lon lat spatial reference systems,
> you can't insert these into a geography table.
New description:
 Both Paul and I recall that the geography type had support for other long-
 and this:
 INTO test3;
 -- this correctly rejects as expected
 SELECT geography(ST_GeomFromText('POINT(1 1)', 26986)) As geog;
 erros out with;
 ERROR:  Only lon/lat coordinate systems are supported in geography.
 I thought it was a regression bug, but trying the above on a 2.1.0 install
 I found lying around yields the same results.  So it seems while the
 geography type supports non-4326 lon lat spatial reference systems,  you
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2941#comment:1>
