[postgis-tickets] [PostGIS] #3076: Unqualified function calls break postgres_fdw compatibiliy
PostGIS trac at osgeo.org
Wed Apr 1 08:29:48 PDT 2015
 Reporter:  fphilipe  |       Owner:  robe
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.7
Component:  postgis   |     Version:  2.1.x
 Keywords:            |
Comment(by rdunklau):
 If I understand the proposed fix correctly, it would involve hard-coding a
 set of "often used schemas".
 IMHO, this is really error-prone: either postgis is relocatable, and any
 schema should be good, or it is not, and a fixed schema should be used.
 Since postgis pretends to be relocatable, it should use the user-specified
 schema correctly, by using the @extschema@ placeholder.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3076#comment:8>
