[postgis-tickets] [PostGIS] #3076: Unqualified function calls break postgres_fdw compatibiliy
PostGIS trac at osgeo.org
Wed Apr 1 08:36:01 PDT 2015
 Reporter:  fphilipe  |       Owner:  robe
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.7
Component:  postgis   |     Version:  2.1.x
 Keywords:            |
Comment(by robe):
 rdunklau,
 Yap that's the path we are going down.
 See this thread -
 http://lists.osgeo.org/pipermail/postgis-devel/2015-March/024806.html
  The only issue I suspect we'll run into is if the person then relocates
 the extension again, I think the old one would be stuck because I suspect
 the extension machinery would then hard-code this new schema at extension
 install time and ALTER EXTENSIO SET SCHEMA would then use the old path
 making the functions unusable.  I have to test that theory, but I suspect
 that will be the downside of using only @extschema@
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3076#comment:9>
