[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
PostGIS trac at osgeo.org
Sun Apr 5 03:20:57 PDT 2015
  Reporter:  strk         |       Owner:  nicklas
      Type:  enhancement  |      Status:  reopened
  Priority:  blocker      |   Milestone:  PostGIS 2.2.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Comment(by robe):
 Oops I guess winnie is complaining because of this.  I was also testing on
 my windows mingw64 PostgreSQL 9.5 and get the same failure on cunit
 Suite: effectivearea
   Test: do_test_lwgeom_effectivearea_lines ...FAILED
     1. cu_effectivearea.c:35  -
 CU_ASSERT_EQUAL(ea->res_arealist[i],the_areas[i])
   Test: do_test_lwgeom_effectivearea_polys ...passed
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:27>
