[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
PostGIS trac at osgeo.org
Mon Apr 6 02:49:38 PDT 2015
  Reporter:  strk         |       Owner:  nicklas
      Type:  enhancement  |      Status:  reopened
  Priority:  blocker      |   Milestone:  PostGIS 2.2.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Comment(by nicklas):
 Ok, the problem was that qsort gives unpredictable result when comparing
 identical values. Now, force the ordering to be consistent. I cannot see
 any performance penalty, so it is probably quite small even if compare-
 function is called many times.
 fixed in r13423
 Now let's see if both winnie and debbie is happy.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:28>
