[postgis-tickets] [PostGIS] #3412: geometry intersects edge on TopoGeo_addLinestring with tolerance 0.001
PostGIS trac at osgeo.org
Tue Dec 29 02:48:25 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.2.1
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 I'd need some confirmation on this bug because I'm seeing a really odd
 behavior in the geos snapper.
 In particular, the 2-vertices vertical line being added fails to snap on
 _all_ the vertices on the existing edge that visually appear to be within
 tolerance distance from the line. Instead, it only snaps to the _one_
 endpoint !!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3412#comment:3>
