[postgis-tickets] [PostGIS] #3412: geometry intersects edge on TopoGeo_addLinestring with tolerance 0.001
PostGIS trac at osgeo.org
Tue Dec 29 02:57:35 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.2.1
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 I was wrong, the snapping is correct. Only the last edge point is below
 tolerance from input, the other two points are very close but higher than
 tolerance.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3412#comment:4>
