[postgis-tickets] [PostGIS] #3022: ValidateTopology error description order should match order of ids
PostGIS trac at osgeo.org
Tue Jan 27 11:56:37 PST 2015
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.7
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by robe):
 Yes it should be noted in docs that they were swapped before.
 I would just put a
 CHANGED: 2.0.7 .. id, id1 for error edge crosses node were changed from
 node_id, edge_id to edge_id, node_id to be consistent with the error
 description.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3022#comment:2>
