[postgis-tickets] [PostGIS] #3022: ValidateTopology error description order should match order of ids
PostGIS trac at osgeo.org
Thu Jan 29 02:14:46 PST 2015
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.7
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 But CHANGED 2.0.7 could make you think 2.1.0 had the new behavior already.
 Should we then specify a first patch version for every branch ? Or just
 forget about backporting the fix to the 2.0 branch ? It's not a critical
 fix after all. Actually is a real change in behavior. Maybe better to just
 change in 2.2.0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3022#comment:3>
