[postgis-tickets] [PostGIS] #3318: ST_MapAlgebra with mask seems to hard-code distance 1 instead of inferring distance from mask matrix
PostGIS trac at osgeo.org
Mon Oct 5 22:02:30 PDT 2015
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I've moved this from the now closed mask documentation #2603 to here
 DROP TABLE IF EXISTS shapes;
 CREATE TABLE shapes(rid integer, rast raster);
 INSERT INTO shapes(rid,rast)
 VALUES ( 1, ST_AsRaster(
                 ST_Buffer(
                         ST_GeomFromText('LINESTRING(50 50,150 150,150
 50)'), 10,'join=bevel'),
                         200,200,ARRAY['8BUI'], ARRAY[118], ARRAY[0]) );
  SELECT st_mapalgebra(rast,1,'st_mean4ma(double precision[], int[],
 text[])'::regprocedure,'{{1,0,1,1,1}, {1,0,1,1,1}, {1,0,1,1,1},
 {1,0,1,1,1}, {1,0,1,1,1}}'::double precision[],false)
 FROM shapes;
 Gives error:
 ERROR:  rt_pixel_set_array: mask dimensions 5 x 5 do not match given dims
 3 x 3
 It's my understanding based on dusty's comments that the neighborhood size
 should be inferred from the mask size, so there seems to me something
 wrong here.
 Bborie's comments copied from other ticket
 Distance is two pixels left, right, up, down from the pixel of interest...
 2 2 2 2 2
 2 1 1 1 2
 2 1 0 1 2
 2 1 1 1 2
 2 2 2 2 2
 So the distance x/y are correct. As for that error message, I'll need to
 dig.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3318>
