[postgis-tickets] [PostGIS] #3318: ST_MapAlgebra with mask seems to hard-code distance 1 instead of inferring distance from mask matrix
PostGIS trac at osgeo.org
Mon Oct 5 22:03:46 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I've moved this from the now closed mask documentation #2603 to here
> DROP TABLE IF EXISTS shapes;
> CREATE TABLE shapes(rid integer, rast raster);
> INSERT INTO shapes(rid,rast)
> VALUES ( 1, ST_AsRaster(
>                 ST_Buffer(
>                         ST_GeomFromText('LINESTRING(50 50,150 150,150
> 50)'), 10,'join=bevel'),
>                         200,200,ARRAY['8BUI'], ARRAY[118], ARRAY[0]) );
>  SELECT st_mapalgebra(rast,1,'st_mean4ma(double precision[], int[],
> text[])'::regprocedure,'{{1,0,1,1,1}, {1,0,1,1,1}, {1,0,1,1,1},
> {1,0,1,1,1}, {1,0,1,1,1}}'::double precision[],false)
> FROM shapes;
> Gives error:
> ERROR:  rt_pixel_set_array: mask dimensions 5 x 5 do not match given dims
> 3 x 3
> It's my understanding based on dusty's comments that the neighborhood
> size should be inferred from the mask size, so there seems to me
> something wrong here.
> Bborie's comments copied from other ticket
> Distance is two pixels left, right, up, down from the pixel of
> interest...
> 2 2 2 2 2
> 2 1 1 1 2
> 2 1 0 1 2
> 2 1 1 1 2
> 2 2 2 2 2
> So the distance x/y are correct. As for that error message, I'll need to
> dig.
New description:
 I've moved this from the now closed mask documentation #2603 to here, I'm
 still having issue with this even as of r14198 even though dusty has made
 some changes.
                 ST_Buffer(
 FROM shapes;
 Gives error:
 3 x 3
 It's my understanding based on dusty's comments that the neighborhood size
 should be inferred from the mask size, so there seems to me something
 wrong here.
 Distance is two pixels left, right, up, down from the pixel of interest...
 2 2 2 2 2
 2 1 1 1 2
 2 1 0 1 2
 2 1 1 1 2
 2 2 2 2 2
 dig.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3318#comment:1>
