[postgis-tickets] [PostGIS] #3335: Handle parallel make properly
PostGIS trac at osgeo.org
Fri Oct 16 23:05:36 PDT 2015
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 NOTE: the fix makes parallel builds succeed here, and I could not find a
 trace of duplicated work (two threads doing the same thing twice) -- but I
 might not have looked carefully enough
 Tests welcome
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3335#comment:3>
