[postgis-tickets] [PostGIS] #3335: Handle parallel make properly
PostGIS trac at osgeo.org
Fri Oct 16 23:23:14 PDT 2015
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Comment (by robe):
 So if this works, we could backport to 2.1 right or you see an issue with
 that.
 We can configure travis to do parallel builds I think or at least I
 thought I saw mloskot do that for geos.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3335#comment:4>
