[postgis-tickets] [PostGIS] #3335: Handle parallel make properly
PostGIS trac at osgeo.org
Fri Oct 16 23:43:55 PDT 2015
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 I don't feel any need to backport it, but it should be safe to do.
 Having some bot build in parallel might help to find out how much it
 speeds up build times (assuming we can see info about times multiple
 builds in a single page)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3335#comment:5>
