[postgis-tickets] [PostGIS] #3338: postgis extension that returns not supported for all Raster functions if raster not available
PostGIS trac at osgeo.org
Mon Oct 19 01:03:02 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.0.x
Resolution:           |   Keywords:
Comment (by strk):
 If astrodog wipes out raster from postgis extension, then "CREATE
 EXTENSION POSTGIS" would give you postgis and no raster, how would you
 then enable raster in a database ? There'd be no "CREATE EXTENSION" for
 you to use, unless astrodog goes on with doing more work, and those
 packages would still be incompatible with a manually-built postgis.
 Implementing shells for the sake of printing UNSUPPORTED may be a
 solution, yes, as long as there's then a way to add raster if needed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3338#comment:7>
