[postgis-tickets] [PostGIS] #3346: PostGIS 2.0 branch does not regress against PostgreSQL 8.4
PostGIS trac at osgeo.org
Thu Oct 22 23:08:27 PDT 2015
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.0.8
Component:  postgis  |    Version:  2.0.x
 Keywords:           |
 I just resetup 8.4 on new debbie with last released 8.4 which is 8.4.22.
 Even on old debbie, the PostGIS 2.0 has been choking on 8.4 though seems
 for other reasons (might be because it's an older micro).  On new debbie,
 I get this.
  PostgreSQL 8.4.22 on x86_64-unknown-linux-gnu, compiled by GCC gcc
 (Debian 5.2.1-21) 5.2.1 20151003, 64-bit
  Postgis 2.0.8SVN - r - 2015-10-23 05:56:48
    GEOS: 3.4.3dev-CAPI-1.8.3 r0
    PROJ: Rel. 4.9.2, 08 September 2015
 http://debbie.postgis.net:8080/job/PostGIS_Regress/1798/consoleFul
  regress_index_nulls .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_26_diff)
 --- regress_index_nulls_expected        2015-10-09 02:56:53.722986949
 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_26_out
 2015-10-23 05:58:02.083971536 +0000
 @@ -1,4 +1,6 @@
  NOTICE:  table "indexnulls" does not exist, skipping
 +ERROR:  parse error - invalid geometry at character 88
 +ERROR:  parse error - invalid geometry at character 87
  NOTICE:  table "indexempty" does not exist, skipping
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  out_geometry .. ok
  out_geography .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_66_diff)
 --- tickets_expected    2015-10-09 02:56:53.478987101 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_0_pg8.4w64/test_66_out
 2015-10-23 05:58:06.127969707 +0000
 @@ -121,7 +121,7 @@
  ERROR:  Shell is not a line
  #695
  ERROR:  First argument must be a LINESTRING
 -#696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
  #720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
 11028513.63)
  #723|0101000020e61000006284f068e33826c00000000000004440
  #723|0107000020e610000000000000
 @@ -217,7 +217,7 @@
  #1697.2|0
  #1697.3|1024
  #1734.1|1026
 -#1755|01e9030000000000000040554000000000008041400000000000000000
  #1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
  #1791|4.7
  ERROR:  ST_Segmentize: invalid max_distance 0 (must be >= 0)
 @@ -243,4 +243,4 @@
  #2424|MULTILINESTRING((0 0,10 0,24 3,30 10))
  #2427|POINT(-1 0)
  #2168|5340.76237395|5340.76237395|0
 -#2870|Point[G]
 +ERROR:  parse error - invalid geometry at character 28
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  in_geojson .. ok
  uninstall .. ok (3699)
 Run tests: 85
 Failed: 2
 Makefile:172: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.0/regress'
 GNUmakefile:14: recipe for target 'check' failed
 make: *** [check] Error 1
 Build step 'Execute shell' marked build as failure
 ERROR: Failed to set Jenkins Identity header on email.
 java.lang.NullPointerException
         at
 org.jenkinsci.main.modules.instance_identity.InstanceIdentity.get(InstanceIdentity.java:126)
         at
 jenkins.plugins.mailer.tasks.MimeMessageBuilder.setJenkinsInstanceIdent(MimeMessageBuilder.java:188)
         at
 jenkins.plugins.mailer.tasks.MimeMessageBuilder.buildMimeMessage(MimeMessageBuilder.java:166)
         at hudson.tasks.MailSender.createEmptyMail(MailSender.java:391)
         at hudson.tasks.MailSender.createFailureMail(MailSender.java:260)
         at hudson.tasks.MailSender.createMail(MailSender.java:178)
         at hudson.tasks.MailSender.run(MailSender.java:107)
         at hudson.tasks.Mailer.perform(Mailer.java:141)
         at
 hudson.tasks.BuildStepCompatibilityLayer.perform(BuildStepCompatibilityLayer.java:75)
         at
 hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
         at
 hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:779)
         at
 hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:726)
         at hudson.model.Build$BuildExecution.post2(Build.java:185)
         at
 hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:671)
         at hudson.model.Run.execute(Run.java:1766)
         at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
         at
 hudson.model.ResourceController.execute(ResourceController.java:98)
         at hudson.model.Executor.run(Executor.java:408)
 An attempt to send an e-mail to empty list of recipients, ignored.
 Warning: you have no plugins providing access control for builds, so
 falling back to legacy behavior of permitting any downstream builds to be
 triggered
 Triggering a new build of PostgreSQL stop
 Finished: FAILURE
 PostgreSQL 8.4 reached end of life in July 2014.
 http://www.postgresql.org/support/versioning/
 So we are not obligated to support it.  Should we bother trying to fix
 this or just put a note on 2.0 that 8.4 reached EOL, and that while
 PostGIS 2.0 still compiles against 8.4, it is no longer a supported
 platform and people should upgrade.
 We don't support 8.4 in 2.1+ up so no issue there.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3346>
