[postgis-tickets] [PostGIS] #3346: PostGIS 2.0 branch does not regress (was: PostGIS 2.0 branch does not regress against PostgreSQL 8.4)
PostGIS trac at osgeo.org
Thu Oct 22 23:25:32 PDT 2015
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 2.0.8
 Component:  buildbots  |    Version:  2.0.x
Resolution:             |   Keywords:
Changes (by robe):
 * owner:  pramsey => robe
 * component:  postgis => buildbots
Comment:
 Turns out I unfairly blamed 8.4 on this.  It was just that 8.4 runs first
 and then the whole build fails when it fails.  I switched to have 9.0 run
 first and it fails in a similar way.
 But what's troubling me is the old debbie gets passed these parts and
 fails on raster.  So seems something about the way I have it setup on new
 debbie is different.
 old debbie is running:
 PostgreSQL 8.4.17 on x86_64-unknown-linux-gnu, compiled by GCC gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
  Postgis 2.0.8SVN - r14305 - 2015-10-22 17:37:14
    GEOS: 3.4.3dev-CAPI-1.8.3 r4073
    PROJ: Rel. 4.9.1, 04 March 2015
 looks same right. I'm a bit bothered the revision numbers aren't coming
 thru on new debbie.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3346#comment:1>
