[postgis-tickets] [PostGIS] #3346: PostGIS 2.0, PostGIS 2.1 branch does not regress (was: PostGIS 2.0 branch does not regress)
PostGIS trac at osgeo.org
Sat Oct 24 12:52:32 PDT 2015
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.0.8
 Component:  buildbots  |    Version:  2.0.x
Resolution:             |   Keywords:
Changes (by robe):
 * priority:  medium => blocker
Comment:
 This seems to be even deeper, rerunning PostGIS 2.1 compiled against GEOS
 3.5.1dev I get similar issues:
 PostgreSQL 9.4.5 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 5.2.1-21) 5.2.1 20151003, 64-bit
   Postgis 2.1.9dev - r14302 - 2015-10-23 15:29:52
   scripts 2.1.9dev r14302
   GEOS: 3.5.1-CAPI-1.9.1 r4110
   PROJ: Rel. 4.9.2, 08 September 2015
 Running tests
  loader/Point .............. ok
  loader/PointM .............. ok
  loader/PointZ .............. ok
  loader/MultiPoint .............. ok
  loader/MultiPointM .............. ok
  loader/MultiPointZ .............. ok
  loader/Arc .............. ok
  loader/ArcM .............. ok
  loader/ArcZ .............. ok
  loader/Polygon .............. ok
  loader/PolygonM .............. ok
  loader/PolygonZ .............. ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ......... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  binary .. ok
  operators .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.4w64/test_27_diff)
 --- regress_index_nulls_expected        2015-10-23 15:29:38.018498182
 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.4w64/test_27_out
 2015-10-23 15:31:04.810598811 +0000
 @@ -1,4 +1,6 @@
  NOTICE:  table "indexnulls" does not exist, skipping
 +ERROR:  parse error - invalid geometry at character 88
 +ERROR:  parse error - invalid geometry at character 87
  NOTICE:  table "indexempty" does not exist, skipping
  regress_selectivity .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  size .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  geography .. ok
  out_geometry .. ok
  out_geography .. ok
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  boundary .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.4w64/test_72_diff)
 --- tickets_expected    2015-10-23 15:29:36.218496087 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.4w64/test_72_out
 2015-10-23 15:31:07.826602292 +0000
 @@ -121,7 +121,7 @@
  ERROR:  Shell is not a line
  #695
  ERROR:  First argument must be a LINESTRING
 -#696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
  #720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
 11028513.63)
  #723|0101000020e61000006284f068e33826c00000000000004440
  #723|0107000020e610000000000000
 @@ -219,7 +219,7 @@
  #1697.2|0
  #1697.3|1024
  #1734.1|1026
 -#1755|01e9030000000000000040554000000000008041400000000000000000
  #1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
  #1780|t
  #1791|4.7
 @@ -258,4 +258,4 @@
  #2704|POLYGON((0 0,0 1,1 1,1 0,0 0))
  #2712|LINESTRING EMPTY
  #2788|f|Self-intersection|POINT(1 1)
 -#2870|Point[GS]
 +ERROR:  parse error - invalid geometry at character 28
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  knn .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  delaunaytriangles .. ok
  in_geojson .. ok
  uninstall .  /var/lib/jenkins/workspace/postgis/branches/2.1/regress/00
 -regress-install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4336)
 Run tests: 93
 Failed: 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3346#comment:2>
