[postgis-tickets] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Wed Sep 9 07:54:17 PDT 2015
polygons
  Reporter:  wimned    |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 I'm looking at this case. It seems that code exist which is meant to
 handle this case (of an edge self-collapsing due to snapping) but it's
 evidently uneffective. The problem is that it calls ST_MakeValid which
 only does something if the input is invalid, which is never the case for
 linestrings. We need code that fixes non-simplicity instead
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:17>
