[postgis-tickets] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Wed Sep 9 08:03:01 PDT 2015
polygons
  Reporter:  wimned    |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 NOTE: the ST_MakeValid is not completely useless for lines but handles the
 collapse-to-singlepoint case, which is still needed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:18>
