[postgis-tickets] [PostGIS] #3274: PostGIS 2.1 dependency on proj.4
PostGIS trac at osgeo.org
Wed Sep 9 14:01:47 PDT 2015
 Reporter:  watsonta  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  high      |  Milestone:  PostGIS 2.1.9
Component:  postgis   |    Version:  2.1.x
 Keywords:  proj4     |
 Installed PostgreSQL 9.4 w/PostGIS 2.1 alongside 9.1 w/PostGIS 2.0 on RHEL
 6.5 to prepare for upgrade. Ran pg_upgrade --check and got library issue:
 Could not load library "$libdir/postgis-2.0"
 ERROR:  could not load library "/usr/pgsql-9.4/lib/postgis-2.0.so":
 /usr/pgsql-9.4/lib/postgis-2.0.so: undefined symbol: pj_get_spheroid_defn
 With help from strk on "postgresql" IRC channel, we identified the problem
 as a broken dependency check. PostGIS 2.1 now requires libproj 4.8.0+
 (instead of 4.6.0+).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3274>
