[postgis-tickets] [PostGIS] #3274: PostGIS 2.1 dependency on proj.4
PostGIS trac at osgeo.org
Wed Sep 9 16:53:58 PDT 2015
  Reporter:  watsonta  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 2.1.9
 Component:  postgis   |    Version:  2.1.x
Resolution:            |   Keywords:  proj4
Comment (by robe):
 watsona -- where did you get your package?  This sounds more like a
 packaging issue than a PostGIS one.  PostGIS 2.1 doesn't require 4.8.0
 (I've run iton 4.7.1 fine for example), but it looks like PostGIS 2.1
 upgrade wiped out the older proj and sadly looks like they are not binary
 compatible.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3274#comment:1>
