[postgis-tickets] [PostGIS] #3278: MySQL FDW Issues with Geometry Type
trac at osgeo.org
Thu Sep 17 17:46:09 PDT 2015
Reporter: ryckingnoaa | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.1.x
Resolution: worksforme | Keywords: MySQL FDW, geometry, polygon
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
1) Yes that issue was fixed. In fact I have a database with a bunch of
foreign tables (using ogr_fdw driver) which I get listed when I do:
SELECT * FROM geometry_columns;
The geometry_columns view is just a table that lists all database columns
of type geometry. Not sure what you think it is or if you have it
confused with something else.
2) The fact you are not seeing some records coming thru from your
mysql_fdw table sounds like it might be an issue with the mysql_fdw
driver. I don't use that driver so don't know. You might want to report
your issue to them and maybe turn on logging on your database if you don't
have it already to see if there is something spitting out.
All my foreign tables where I output PostGIS use the ogr_fdw driver
https://github.com/pramsey/pgsql-ogr-fdw
and all records that are supposed to be there show up when I query them.
This is from a variety of different spatial data sources.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3278#comment:1>
