[postgis-tickets] [PostGIS] #2979: address standardizer doesn't correctly parse street suffix if no ,
PostGIS trac at osgeo.org
Fri Sep 18 00:08:45 PDT 2015
  Reporter:  robe                 |      Owner:  robe
      Type:  defect               |     Status:  closed
  Priority:  medium               |  Milestone:  PostGIS 2.3.0
 Component:  pagc_address_parser  |    Version:  trunk
Resolution:  wontfix              |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 On closer inspection this seems specific to PINE.  Presuamble because
 there is a regex match for PINE in the parseaddress-stcities.ht
 If I change to say:
 SELECT * FROM parse_address('25 OAK ST PROVIDENCE RI 99999');
  num | street | street2 | address1  |    city    | state |  zip  | zipplus
 | country
  25  | OAK ST |         | 25 OAK ST | PROVIDENCE | RI    | 99999 |
 | US
 That said - trying to fix this would probably cause more damage than good.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2979#comment:3>
