[postgis-tickets] [PostGIS] #2220: Support writing the LDID (character encoding of shapefiles)
trac at osgeo.org
Wed Sep 23 14:06:18 PDT 2015
Reporter: francoisb | Owner: mcayland
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: loader/dumper | Version: 2.0.x
Resolution: fixed | Keywords: shapefile encoding
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
OK, at r14090 we will try to be more smart about writing encodings. The
old behaviour was almost certainly bad/wrong, as we were letting shapelib
write a default LDID number that mean WIN-1252 while writing back what we
got from the database, which was by default almost always UTF8. By more
explicitly opening the DBF file as a UTF-* file, we should get a .cpg file
sidecar that indicates UTF-8 and hopefully client software will also be
more happy with our outputs. Unfortunately there's no common LDID value
for UTF-8, so the sidecar seems a necessity.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2220#comment:2>
