[postgis-tickets] [PostGIS] #3250: cu_algorithm warnings
PostGIS trac at osgeo.org
Wed Sep 23 14:12:11 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  2.1.x
Resolution:           |   Keywords:
Comment (by robe):
 http://stackoverflow.com/questions/9941261/warning-this-decimal-constant-
 is-unsigned-only-in-iso-c90 (reading)
 Hmm could it be that your default and debian's is like C99?  I suspect
 that maybe mingw64 warns about lower since it has to use Windows C
 runtimes which are questionably at god knows which version of C standard.
 I think the newer are at lest C90 or C99 or so but older like windows xp
 are at C89.  So might be a similar kind of -- this may not work when you
 run it kind of messages like the PRIblahblahblah thing I told strk to
 close.
 I'm not sure if I really need to worry about windows xp or windows 2000
 users since, well technically Microsoft doesn't support them and this is
 just showing a warning in cunit tests and no where else in code.
 Feel free to dismiss this as a won't fix if you want.
 I get similar warning in cu_varint
 cu_varint.c:155:2: warning: this decimal constant is unsigned only in ISO
 C90 [enabled by default]
   do_test_s32_varint(-2147483648, 5, "FFFFFFFF0F");
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3250#comment:4>
