[postgis-tickets] [PostGIS] #3297: check_gdal regress fails if gdal_enabled_drivers already has drivers
PostGIS trac at osgeo.org
Sat Sep 26 08:33:53 PDT 2015
 Reporter:  robe    |      Owner:  robe
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 2.2.0
Component:  raster  |    Version:  trunk
 Keywords:          |
 I thought I complained about this already, but can't find the ticket.
 Anyway on my windows box where I've got GDAL_DRIVERS set, check_gdal
 always fails.
  check_gdal .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2_pg9.4w64/test_1_diff)
 On closer inspection, it seems the first test runs without setting
 drivers, and assumes the user is at the default state of -- no drivers and
 it also checks end state to assuming again user is running without
 drivers.  This of course is not true when I launch my instances with
 something like
 @SET GDAL_DRIVERS=something
 or have in postgresql conf to have this set.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3297>
