[postgis-tickets] [PostGIS] #3297: check_gdal regress fails if gdal_enabled_drivers already has drivers
PostGIS trac at osgeo.org
Sat Sep 26 08:34:35 PDT 2015
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.2.0
 Component:  raster  |    Version:  trunk
Resolution:          |   Keywords:
Description changed by robe:
Old description:
> I thought I complained about this already, but can't find the ticket.
> Anyway on my windows box where I've got GDAL_DRIVERS set, check_gdal
> always fails.
>  check_gdal .. failed (diff expected obtained:
> /projects/postgis/tmp/2.2_pg9.4w64/test_1_diff)
> On closer inspection, it seems the first test runs without setting
> drivers, and assumes the user is at the default state of -- no drivers
> and it also checks end state to assuming again user is running without
> drivers.  This of course is not true when I launch my instances with
> something like
> @SET GDAL_DRIVERS=something
> or have in postgresql conf to have this set.
New description:
 always fails.
 drivers, and assumes the user is at the default state of -- no drivers and
 something like
 This might only be an issue in PostGIS 2.2 since we started using raster
 GUCS in this, and this is testing the raster gucs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3297#comment:1>
