[postgis-tickets] [PostGIS] #3297: [raster] check_gdal regress fails if gdal_enabled_drivers already has drivers (was: check_gdal regress fails if gdal_enabled_drivers already has drivers)
PostGIS trac at osgeo.org
Sat Sep 26 08:38:47 PDT 2015
drivers
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.2.0
 Component:  raster  |    Version:  trunk
Resolution:          |   Keywords:
Comment (by robe):
 ah found it was at #2988 and was closed as a won't fix.  In 2.2 we can fix
 it though.  Working on a fix now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3297#comment:2>
