[postgis-tickets] [PostGIS] #3280: Almost collinear edges prevent adding a copy of existing edge
trac at osgeo.org
Wed Sep 30 04:35:27 PDT 2015
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.2.0
Component: topology | Version: 2.0.x
Resolution: | Keywords: robustness
Changes (by strk):
* status: new => assigned
* priority: medium => blocker
* milestone: PostGIS 2.1.9 => PostGIS 2.2.0
Comment:
so it looks like the segfault was due to something extraneous, but the 2.2
patch still need more tweaks as it's missing an ORDER BY in comparison
with the 2.1 implementation, which makes the algorithm (also the present
one) not correct.
I'll set target to 2.2.0 and blocker for now, so we don't release before
fixing this, which is a regression (even if I don't have a test handy to
show the regressing part).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3280#comment:12>
