[postgis-tickets] [PostGIS] #3280: Almost collinear edges prevent adding a copy of existing edge
PostGIS trac at osgeo.org
Wed Sep 30 06:58:43 PDT 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  blocker   |  Milestone:  PostGIS 2.1.9
 Component:  topology  |    Version:  2.0.x
Resolution:  fixed     |   Keywords:  robustness
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
 * milestone:  PostGIS 2.2.0 => PostGIS 2.1.9
Comment:
 Alright, I'm happy with trunk as of r14155 -- beside the fix added to 2.1,
 trunk also needed to conform by sorting the close-by nodes and edges by
 distance, which was lost in the port to C.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3280#comment:13>
