[postgis-tickets] r15266 - Refactor logic for ST_MakeEnvelope to be reusable in liblwgeom
Sandro Santilli strk at kbt.io
Fri Dec 2 00:06:10 PST 2016
Author: strk
Date: 2016-12-02 00:06:09 -0800 (Fri, 02 Dec 2016)
New Revision: 15266
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwpoly.c
   trunk/postgis/lwgeom_functions_basic.c
Patch by Bj?\195?\182rn Harrtell via
https://git.osgeo.org/gogs/postgis/postgis/pulls/8
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2016-11-28 15:10:35 UTC (rev 15265)
+++ trunk/liblwgeom/liblwgeom.h.in	2016-12-02 08:06:09 UTC (rev 15266)
@@ -1356,8 +1356,9 @@
 extern LWLINE *lwline_removepoint(LWLINE *line, uint32_t which);
 extern void lwline_setPoint4d(LWLINE *line, uint32_t which, POINT4D *newpoint);
 extern LWPOLY *lwpoly_from_lwlines(const LWLINE *shell, uint32_t nholes, const LWLINE **holes);
-extern LWPOLY* lwpoly_construct_rectangle(char hasz, char hasm, POINT4D *p1, POINT4D *p2, POINT4D *p3, POINT4D *p4);
-extern LWPOLY* lwpoly_construct_circle(int srid, double x, double y, double radius, uint32_t segments_per_quarter, char exterior);
+extern LWPOLY *lwpoly_construct_rectangle(char hasz, char hasm, POINT4D *p1, POINT4D *p2, POINT4D *p3, POINT4D *p4);
+extern LWPOLY *lwpoly_construct_envelope(int srid, double x1, double y1, double x2, double y2);
+extern LWPOLY *lwpoly_construct_circle(int srid, double x, double y, double radius, uint32_t segments_per_quarter, char exterior);
 extern LWTRIANGLE *lwtriangle_from_lwline(const LWLINE *shell);
 extern LWMPOINT *lwmpoint_from_lwgeom(const LWGEOM *g); /* Extract the coordinates of an LWGEOM into an LWMPOINT */
Modified: trunk/liblwgeom/lwpoly.c
--- trunk/liblwgeom/lwpoly.c	2016-11-28 15:10:35 UTC (rev 15265)
+++ trunk/liblwgeom/lwpoly.c	2016-12-02 08:06:09 UTC (rev 15266)
@@ -94,6 +94,28 @@
 	return lwpoly;
+LWPOLY *
+lwpoly_construct_envelope(int srid, double x1, double y1, double x2, double y2)
+	POINT4D p1, p2, p3, p4;
+	LWPOLY *poly;
+	p1.x = x1;
+	p1.y = y1;
+	p2.x = x1;
+	p2.y = y2;
+	p3.x = x2;
+	p3.y = y2;
+	p4.x = x2;
+	p4.y = y1;
+	poly = lwpoly_construct_rectangle(0, 0, &p1, &p2, &p3, &p4);
+	lwgeom_set_srid(lwpoly_as_lwgeom(poly), srid);
+	lwgeom_add_bbox(lwpoly_as_lwgeom(poly));
+	return poly;
 LWPOLY*
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c	2016-11-28 15:10:35 UTC (rev 15265)
+++ trunk/postgis/lwgeom_functions_basic.c	2016-12-02 08:06:09 UTC (rev 15266)
@@ -2075,37 +2075,8 @@
 		srid = PG_GETARG_INT32(4);
-	pa = (POINTARRAY**)palloc(sizeof(POINTARRAY**));
-	pa[0] = ptarray_construct_empty(0, 0, 5);
+	poly = lwpoly_construct_envelope(srid, x1, y1, x2, y2);
-	/* 1st point */
-	p.x = x1;
-	p.y = y1;
-	ptarray_append_point(pa[0], &p, LW_TRUE);
-	/* 2nd point */
-	p.x = x1;
-	p.y = y2;
-	/* 3rd point */
-	p.x = x2;
-	p.y = y2;
-	/* 4th point */
-	p.x = x2;
-	p.y = y1;
-	/* 5th point */
-	p.x = x1;
-	p.y = y1;
-	poly = lwpoly_construct(srid, NULL, 1, pa);
-	lwgeom_add_bbox(lwpoly_as_lwgeom(poly));
 	result = geometry_serialize(lwpoly_as_lwgeom(poly));
 	lwpoly_free(poly);
