[postgis-tickets] [PostGIS] #3675: Relationship functions not using an index in some cases
PostGIS trac at osgeo.org
Sat Dec 3 11:50:49 PST 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.3.2
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 As noted in
 https://lists.osgeo.org/pipermail/postgis-users/2016-December/041779.html
 The spatial index usage doesn't seem to kick in at least in PostgreSQL 9.6
 2.3 (I have checked 9.5 with 2.3, but 9.5 2.2 is fine).
 The issue only arises when you use a longitude / latitude from a table.
 As I noted in email:
 https://lists.osgeo.org/pipermail/postgis-users/2016-December/041789.html
 Spatial index kicks in for common cases of:
 SELECT e.gid
 FROM e1 , e2
 WHERE ST_Intersects(e1.geom, e2.geom);
 SELECT e.gid
 FROM e1
 WHERE ST_Intersects(e1.geom, ST_SetSRID(ST_MakePoint(-10,
 30),4326)  );
 But doesn't in case where longitude and latitude are coming from a table
 SELECT e.gid
 FROM e1 , e2
 WHERE ST_Intersects(e1.geom, ST_SetSRID(ST_MakePoint(e2.longitude,
 e2.latitude),4326)  );
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3675>
