[postgis-tickets] r14941 - Make test for #3573 run only on PG 9.5+
Daniel Baston dbaston at gmail.com
Tue Jun 7 14:55:30 PDT 2016
Author: dbaston
Date: 2016-06-07 14:55:30 -0700 (Tue, 07 Jun 2016)
New Revision: 14941
   trunk/regress/knn_recheck.sql
   trunk/regress/knn_recheck_expected
   trunk/regress/tickets.sql
   trunk/regress/tickets_expected
Modified: trunk/regress/knn_recheck.sql
--- trunk/regress/knn_recheck.sql	2016-06-07 13:49:28 UTC (rev 14940)
+++ trunk/regress/knn_recheck.sql	2016-06-07 21:55:30 UTC (rev 14941)
@@ -220,3 +220,6 @@
 DROP TABLE knn_recheck_geom_nd;
+-- #3573
+SELECT '#3573', 'POINT M (0 0 13)'::geometry <<->> 'LINESTRING M (0 0 5, 0 1 6)'::geometry;
Modified: trunk/regress/knn_recheck_expected
--- trunk/regress/knn_recheck_expected	2016-06-07 13:49:28 UTC (rev 14940)
+++ trunk/regress/knn_recheck_expected	2016-06-07 21:55:30 UTC (rev 14941)
@@ -124,3 +124,4 @@
 #3nd-3|600001|9461|54.3900|54.3900
 #3nd-3|600001|9749|54.5453|54.5453
 #3nd-3|600001|10041|54.6233|54.6233
+#3573|8
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql	2016-06-07 13:49:28 UTC (rev 14940)
+++ trunk/regress/tickets.sql	2016-06-07 21:55:30 UTC (rev 14941)
@@ -966,8 +966,5 @@
 SELECT '#3470', ST_Polygonize(ARRAY[NULL]::geometry[]) IS NULL;
 SELECT '#3470b', ST_Area(ST_Polygonize(ARRAY[NULL, 'LINESTRING (0 0, 10 0, 10 10)', NULL, 'LINESTRING (0 0, 10 10)', NULL]::geometry[]));
--- #3573
-SELECT '#3573', 'POINT M (0 0 13)'::geometry <<->> 'LINESTRING M (0 0 5, 0 1 6)'::geometry;
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected	2016-06-07 13:49:28 UTC (rev 14940)
+++ trunk/regress/tickets_expected	2016-06-07 21:55:30 UTC (rev 14941)
@@ -294,4 +294,3 @@
 #3437e|5
 #3470|t
 #3470b|50
-#3573|8
