[postgis-tickets] r14942 - Make test for #3573 run only on PG 9.5+
Daniel Baston dbaston at gmail.com
Tue Jun 7 15:11:30 PDT 2016
Author: dbaston
Date: 2016-06-07 15:11:30 -0700 (Tue, 07 Jun 2016)
New Revision: 14942
   branches/2.2/regress/knn_recheck.sql
   branches/2.2/regress/knn_recheck_expected
   branches/2.2/regress/tickets.sql
   branches/2.2/regress/tickets_expected
Modified: branches/2.2/regress/knn_recheck.sql
--- branches/2.2/regress/knn_recheck.sql	2016-06-07 21:55:30 UTC (rev 14941)
+++ branches/2.2/regress/knn_recheck.sql	2016-06-07 22:11:30 UTC (rev 14942)
@@ -220,3 +220,6 @@
 DROP TABLE knn_recheck_geom_nd;
+-- #3573
+SELECT '#3573', 'POINT M (0 0 13)'::geometry <<->> 'LINESTRING M (0 0 5, 0 1 6)'::geometry;
Modified: branches/2.2/regress/knn_recheck_expected
--- branches/2.2/regress/knn_recheck_expected	2016-06-07 21:55:30 UTC (rev 14941)
+++ branches/2.2/regress/knn_recheck_expected	2016-06-07 22:11:30 UTC (rev 14942)
@@ -124,3 +124,4 @@
 #3nd-3|600001|9461|54.3900|54.3900
 #3nd-3|600001|9749|54.5453|54.5453
 #3nd-3|600001|10041|54.6233|54.6233
+#3573|8
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql	2016-06-07 21:55:30 UTC (rev 14941)
+++ branches/2.2/regress/tickets.sql	2016-06-07 22:11:30 UTC (rev 14942)
@@ -950,8 +950,5 @@
 -- #3565
 SELECT '#3565',ST_SetPoint(st_geomfromtext('LINESTRING EMPTY'), 0, ST_MakePoint(1,1));
--- #3573
-SELECT '#3573', 'POINT M (0 0 13)'::geometry <<->> 'LINESTRING M (0 0 5, 0 1 6)'::geometry;
 -- Clean up
 DELETE FROM spatial_ref_sys;
Modified: branches/2.2/regress/tickets_expected
--- branches/2.2/regress/tickets_expected	2016-06-07 21:55:30 UTC (rev 14941)
+++ branches/2.2/regress/tickets_expected	2016-06-07 22:11:30 UTC (rev 14942)
@@ -292,4 +292,3 @@
 #3470|t
 #3470b|50
 ERROR:  Cannot set point values on EMPTY geometry, use ST_AddPoint to add points
-#3573|8
